mini-vac hose connector
EQUINOX400
The outside diameter of the end of the vac hose for the minivac is close to 1 1/4 inches. I need a straight connector to connect it to a fitting that has the same OD. Where can I find that animal?
Try a short length of 1 1/4" PVC pipe.  Even if you have to buy  the whole length it will probably cost less than most adapters.
Also a PVC pipe straight connector for 1" pipe might fit.  The OD of 1" pipe is about 1 1/4" and that fits into the straight connector.
I would remove the tool end Festool hose connector and take it to a big box for test  fitting.
