Mistake...Too many Domino holes?
tallnfast
So I have a rather large project that I simply can throw this piece away and start over
i have two 8mm holes that are not suppose to be there... anyone have suggestion on "fixing/hiding" the holes
i search the internet for a solution, but for some reason i must be the only one that makes mistakes with this tool?
any advice would be appreciated!
Make a face grain Domino out of the base wood, glue, insert, finish.
The light spot is a face grain Domino filling an oooopppppps.
Cut the domino, to where it will fill most of the hole leaving enough to be filled, then fill it with a color matched crayon, or a white filler then use some pigments to color match and paint  the filler with earth pigments  to match.Then stain and or clear coat...
Never done this, but next time I make that mistake I would try getting some closely matching face grain from a scrap of similar wood, gluing it to the end of a Domino and then trimming to the shape of the Domino, maybe just a hair bigger.  Cut the other end of the Domino to appropriate length, do a test fit.  If it doesn't look close, try again until satisfied, then glue up, sand lightly and apply finish with the rest of the project.
