First post on FOG, so not sure this is the right sub-forum, but here it goes.
I recently purchased & returned two non-Festool sliding 12" miter saw. My goal was to replace my 10-12 year old Bosch fixed 10-inch.
The reason for both returns was an unacceptable amount of play in the blade. I noticed this on the first saw when I did a 'bump and cut' and realized no material was actually removed from the wood, AND the blade paint (new blade) was smeared all over the surface that should have been cut. It appears the blade, on contact, deflected and just buffed the end of the wood.
Thinking I got a bad copy, I decided to try another brand. This time I didn't cut any wood, but just wiggled the blade (saw unplugged of course). The second saw felt even worse. Thinking I must be crazy, I went back to my old Bosch, and found it had close to zero play when wiggled. One key difference between my saw and the new ones, is my saw looks to have a drive shaft coming directly from the motor, while the other have gears, bearings, and bushings that transfer power from the motor to the blade.
My question here is, do you think I just happened to find two lemons, or has build quality dropped so much in the last decade that this is now the new normal? I'm now leaning toward a Kapex, and was curious if anyone has had similar experiences with other brands, or even their Kapex?
Thanks, Dave
Thanks, Dave
