In the past, I have made boxes for various purposes using plywood and mitering the edges to be joined. I then use packing tape to join them in a flat sheet. I add glue to the joints and fold up to make the box.
I am planning on doing the same shortly for a small rolling stool with storage.
When I have done this on the table saw I would first cut all the pieces to size. Then I would make a sacrificial fence with a relief cut in the bottom so that waste would not kickback. I would raise the blade at 45 degrees until it was slightly buried in the fence. The relief is taller than the waste and about 3/16" wide so plenty of room for the waste to rattle around. I do stand clear of the waste but I have never experienced any kickback.
Fast forward to 2021. I have a Festool track saw.
Do I cut the miters along the length of the sheet with the track saw? And then cut the mitered board into the four pieces I need?
Or do I use the track saw to make the blanks and use the table saw to make the miters.
The stool will be about 16" x 16". It will have casters and an upholstered lift off lid. The finished height will be 18". I guess the cut height will be in the 15" range.
So if I am using one long board it will need to be 60 + inches long by 18" wide.
Any thoughts?
To check my 45 degree angle, I would cut a piece about 12" wide and rip it into four equal-sized strops (about 3" x 12"). I would fold that up and make sure the joints all closed nicely.
I have never made any angle cuts using the track saw. Anything I should watch out for?
Any thoughts?
