Francisco, sorry I do not have any plans as I was building on the fly. I just used the measurements from the MFT top including the side extrusion profiles and systainers and adjusted to my preferred working height and built from there. [smile]
Yes it will fit through a 36" doorway, the overall height with 27 3/8" with the MFT top is 34 5/8". You can also roll with the MFT top in a 36" opening because it is 30 3/8" wide. HTH.
Nice build! How did you came up with the height? I would like to keep the top at 90cm, since the standard Festool workheight it 90cm. So it would be the same height as you kapex on its base, or the Festool sawtable. Perhaps i miscalculated it, but it seems your build is slightly lower?
