New to the group, recent Festool buyer/user.
Has anyone put some thought into how to update the power handling capacity of the CTs? I know were talking about warranty issues but I would think that some relatively simple electrical engineering would be able to add a second outlet to the CTs or at least make the one outlet capable of delivering closer to the required current for a Kapex and the CT at the same time and avoid some of the motor burning issues that seem to be plaguing specifically the Kapex 120.
I personally like running a 10GA extension cord to a bigger block that I plug multiple tools into at once. I've never had a tool burn out other than a Bosch hammer drill that was borrowed and run constantly on 100' 12-14GA cord.
Certainly, if I thought I'd have an issue running a Kapex off a CT I'd separate them on two circuits but now theres no auto tool switching function which, in my mind, largely obviates the point of the CT.
If you dedicated the CT to a 20A kitchen outlet or the panel directly with a fat cord I would think you wouldn't have any issues with current but is the line power wiring inside in need of an upgrade to not cause problems? It's a $800 vacuum so I'd say if I have to buy some other components and switch them out to make it bulletproof I'll do that and take my chances with any other warranty issues.
