rnt80
- Mar 30, 2008
My last job (the closet redo) finally put me over the edge. I had a lot of cutting to do on site and ended up balancing pieces on top of my CT22 to do most of the work. I've been looking at getting an MFT with Steve's new ts55 jig but decided to go this route for now. I read the article about the Finn bench system when it was in FWW earlier this year and was intrigued by the possibilities. After looking at his design and that of Alan Mohr's on this site I decided to make a few changes. I decided not to build the bases for a couple of reasons. These benches will primarily be used on site so the bases needed to break down easily, something Finn's original idea wasn't made for. The bases I ended up using are from IKEA and cost $30 each. The only change I had to make was where the legs attach to the bottom shelf. It was supposed to screw together, instead I bought some 1/4-20 3" hanger bolts and wing nuts so that I could easily take that joint apart. All told it takes about 2-3 minutes to assemble/disassemble the bases.
The tops of the benchs have been drilled out with 20mm holes using a Festool 20mm bit. I used the LR32 system to space the holes 128mm OC along the length of the bench and 64mm OC across the width. On one side of each of the benches I routed a t-track so that I could slide Festool clamps in and out to hold pieces vertically (I have the same feature on my assembly bench in the background). The benches are approximately 8' long, which is too big for my old Pathfinder so I cut out recesses on at each end of the bench. This will allow me to strap them to the roof of my car when I take them for the next install. The cut out that is in the middle of the bench is just for a hand hold.
The bottom of the benches have a lip so that I can clamp them to the bases. After using them today to plane down a piece of stock I don't think that'll be necessary, they are solid as a rock. The bottom of one of the bases is offset so that I can push the two together to create a bigger space and still have one of the t-tracks accessible.
I topped them off with a couple of coats of poly. I plan on adding a larger piece of mdf to the tops of the IKEA bases just to provide more surface area for the benches to rest on.
