A A.I. Member Joined Mar 21, 2010 Messages 2 Mar 21, 2010 #1 my last order of rubin sanding discs where the new multi jet stream discs. I was wondering when the replacement pads they are designed for would be available?
peter halle Festool Moderator Festool Moderator Joined Jul 8, 2007 Messages 13,126 Mar 21, 2010 #2 You can order the pads now thru your dealer. You can also use either paper with your existing pad although without the benefits of the new design. Here is a link with discussions and links. http://festoolownersgroup.com/ask-festool/multi-jetstream-pads/
A A.I. Member Joined Mar 21, 2010 Messages 2 Mar 21, 2010 #3 Peter Halle said: You can order the pads now thru your dealer. You can also use either paper with your existing pad although without the benefits of the new design. Here is a link with discussions and links. http://festoolownersgroup.com/ask-festool/multi-jetstream-pads/ Click to expand... Thanks, Peter. [smile]
