Bugsysiegals
- Mar 19, 2016
mrFinpgh said:I work in technology as a 'technical architect', meaning I do a lot of diagramming, documenting, planning, online workshops, and some coding.
I use a 13" macbook pro for all of these tasks and don't have any external monitors set up. Now I'm wondering whether there might be some benefits to having more than one.
Reading this discussion, I am wondering what the needs are that drive having so much display real estate. Is it about viewing items in a larger screen? Or having more things available to view without leaving the context of the 'main' work item? Or having a 'dashboard' view of all applications at one time?
Does having this much stuff on multiple screens at one time improve the work experience? I would be very concerned about the costs of context switching, if I could always see someone messaging me in slack or always know when a client sends me an email. I think this would be highly individualized in terms of workflow, but often it seems beneficial to turn off as much as possible and focus on the tasks at hand without interruptions or distractions.
To echo [member=61254]mino[/member] , I think it would be good to approach is to consider what is really needed and what is going to be most ergonomic in terms of what someone can comfortably visually track.
There's definitely enough screen to split applications side-by-side with a large monitor; however, this isn't something I do often, other than comparing code. For me, while I have a horizontal scroll wheel on my mouse, I simply prefer to avoid it whenever possible and it's easier when you can see everything you need all at once.
Wider monitors allow me to see many more columns of spreadsheet data which makes it easier and faster to digest and compare. They allow me to most times see very long lines of complex coding statements and to even compare 2 different versions of code side-by-side with a diff program like WinMerge without much if any horizontal scrolling necessary.
And regardless of size, I share and present information with my colleagues. Multiple monitors means I can move everything I'm working on to my 2nd monitor, move what I want to share to the primary monitor, and share without people accidently seeing any sensitive information or my FOG browser window.
