My ideal workshop, aka how I would mess it up ..
mino
Czech Republic
Here is a thread about "My ideal workshop" where I will contemplate on how I would setup my kit - had I known what I know now.
Of course, things *I* consider "ideal" may be junk for others.
To the record out what *I* define as "ideal" is approximately per below:
0) firstly I see "cost" as a 3-sided triangle of $, time and space
1) good-enough accuracy so a dry-fit fits
2) best possible accuracy at reasonable cost => go for the cost/value inflection point or just slightly beyond
3) minimal "operating costs" /this translates mostly to space used when shop is "mothballed"/
I expect this to be a long-living-posts thread for me. Will be changing the posts as my views change over time.
1x CTL 26 AC + Bluetooth module  /consideration: CTM version with air-flow sensor if expect to use commercially at some point/
wood processing role:
Festool CTL/CTM series basic main filter /non-AC/
Festool CTL/CTM 26 AutoClean bags
Festool CT-VA
dry/concrete role:
CTL/CTM series High Performance main filter /AC/
Dust-port closing accessory for deep-cleaning
no bag
what-if role:
Festool CTH series main filter
Festool CTH 26 H-class bag
hoses and accessories:
1x 3.5 m 27/32 AS hose (default with vac) integrated with 4m "green" plug-it cable
1x 3.5 m D36 m AS hose (from Workshop Cleaning Set) + BT remote
2x set of three D36 short metal extension tubes /fit in Systainer/
TS 55 FEBQ + HKC 18  /or TSC 55 REBQ, with riving knife/
PSBC 18 + track/circle accessory set
track/rail setup:
1x  FS/2 1400 LR32  /semi-permanently joined with one 376 into a 1776/
1x  FS/2 1016 LR32  /from 1400 LR32/
1x  FS/2 632  /from 1400/
    mobile "shortie" set in systainer:
1x  FS/2 376 LR32  /from 1400 LR32/
2x  FS/2 376  /from 1400/
2x  Makita connector set
    accessories:
1x  TSO GRS 16 PE
1x  TSO PGS  /tbc. which parts exactly/
2x  GECKO DOSH set
LR32 system:
LR32 basic set
dedicated router bits: 3mm, 5mm, 8mm /8mm shank/
Hammer drill 5J class, any mass market make
Hobby framing/construction tools:
1x  Ryobi AirStream 16 gauge nailer
1x  HK 85 + grooving accessory /note: NAINA/
Dust collection:
Festool dust shroud for drilling
Festool dust shroud for buckets
