I finally broke down and purchased the mfk 700 laminate trimmer kit for a big 60 sheet install job. I got the kit and went over the machine took the base off put the other one on etc. I was suprised it didnt come with the edge guide it shows it in the systainer picture shows it in the owners manual and its on 3 of the you tube videos i watched.
My first job was to mortise out some 2x material to install a metal jamb. It was smooth running and cut the presure treated lumber with absolutely no hesitation. I will update my review when i get done with my laminate job.
A few things festool needs to seriously consider making for this tool is a small plunge base or a base so you can see the bit if you are freehanding something you have to guess where you dree your lines. The other accesory they need to make asap is a scribe to join 2 pieces of laminate together. Using a track saw to seam laminate (as suggested by the festool guy) is ridiculous. The systainer needs at least a place to store a minimum of 4 bits safely that way they are all together in one place when you need them. I think if the powers to be at festool would work on these items then they can be a serious contender to compete with the bosch or porter cable laminate trimmer kit.
