- Nov 3, 2007
We only had a few days actually over 100 degrees this summer, though the heat index was well over most of the summer. So, my honey had me making a new patio. The previous owner had laid down flagstone and then it looked like poured some concrete with real small aggregate in between. It appeared that that was done dry and then wetted. There were some French doors added by them also that were done pretty poorly and the stoop was railroad ties surrounding a mas of sand and the same flagstone treatment on top.
Anyway, it all looked pretty crappy and the railroad ties had to go. So I took all of that junk out, reused the flagstones around back, up on a cliff. The cliff is there because they had to cut out a flat spot from the hill that is this property.
After I moved all that stone to the back, I had to do some excavation to make a proper stoop and generally lower the whole area. I wanted to make it Tejas black gravel and Blanco (white) limestone. I first stained all of the foundation, sidewalk and existing concrete stoop (the other front door) using Cola colored KEMIKO acid stain. I thought it went real well with the stone on the house.
I also made a form, put in some remesh, and mixed 18 80-lb. bags of Quikrete to make a foundation slab for my new stoop.
Tools used so far: several Bully Tools, a cheap wheelbarrow, plus KAPEX, TS 55 & T 15 +3 for the forms.
[attachthumb=#1]
Next, I laid cinder blocks to get the height I needed to get up to the door.
[attachthumb=#2]
I then surrounded the blocks with 2 rows of limestone chop.
[attachthumb=#3]
So then, I capped the whole thing with 3 2'x4' limestone slabs and grouted between them. After the grout cured, I took out the Rotex 150 and went to town in gear driven mode. It cleaned it all up likety split.
The stoop was a little too high for only one step so I took more of the 2'x4' limestone slabs and made a pad in front of it, sort of like another step. I used broken pieces (most of the pallet was broken pieces) as a walkway and spread Tejas black gravel all around. Oh, I also laid down landscaping fabric.
[attachthumb=#4]
[attachthumb=#5]
I like it but more importantly, Veronica likes it.
Now I'm working on the back...
[attachthumb=#1]
[attachthumb=#2]
[attachthumb=#3]
[attachthumb=#4]
[attachthumb=#5]
