sebcbien
- Aug 5, 2014
Hello,
First post here from a fresh new hobbyist carpenter.
I've read a lot before starting to build my workbench, I started with the idea to build a roubo style workbench but ended with an MFT and a plywood base station on wheels.
It is still not finished, but the main assembly is done and the main ideas are present.
Here is the sketchup plans I've made, but during the building I changed my mind on some points.
Here is the front view:
The main thing you will notice is the foot of the mft (4 plywood of 10/10cm).
There are three reasons:
- I wanted more space under the mft for a drawer/dust collection.
- I wanted a place to store the TS75 under the CMS when not in use.
- I'm tall (1m95) and put the top level of the MFT/3 at 115cm. I've never had the chance to work at this level and although it seems very comfortable with the tests, I wanted to be able to lower the height afterward if it was too much.
[attachthumb=2]
On the rear view, I want to show the place I made to store the big CMS rail when not in use
[attachthumb=1]
I did not wanted to make drawers for the systainers, the main reason is that I do not have a lot of them and that they are easily accessible like that, the systainers for the domino and the TS75 are sideways because it's the easiest way to insert and retrieve the tools from the systainers.
I still have to do a lot of things but I wanted to share the plans earlier so that I can receive advices one some points before they are built.
The next points to build are the station to hold the TS75 when not in use, the drawer under the MFT, the electrical wiring with a master/slave outlet for my Nilfisk ATTIX ... ... ... ...
[attachthumb=2]
[attachthumb=1]
