Nails set
Rollin22Petes
So I finally got fed up with all the cheap China made nail sets available at all the big box stores and bought me a set of Starretts. Was really hard to pay $70 for a set but I'm no stranger to Starrett and there quality they really look and feel nice plus they get excellent reviews. Hopefully if I can keep up with all of them it will be the last set I buy.
Can you provide a link to the Starrett nail set you purchased?  I love Starrett stuff and was just thinking about needing a nail set yesterday.  Thanks
I just found them on Amazon. $57 for set of five. I plan on getting a set for myself.
I've had pretty good luck with the KISS brand nails set that I picked up at Walgreens.
[member=19475]yetihunter[/member], I would have pegged you as someone who had their nails done professionally
I just remembered that I already ran with this gag.
Something about pedicures and a die grinder.
I bet those Starrets will be sweet.  I rarely have to use a nail set anymore since switching over to pneumatics, so for those who might not want to spend the $ for a set, here is one that I switched to years ago.  Kinda hard to find at times in stores or the internet:
I use snap on punches for nail set. I dislike regular nail set because there are too short. It would be nice if manufacturers made them a couple inches longer.
I know they don’t have the dimple on the end.
Rick.
Rick.
The Stanley Cushion Grip (older square top)  or Dynagrip (newer round top) are longer than many at 5". I specifically got them because they are an inch or so longer than many/ most.
I usually use Spring Tools nail sets. Allows me to quickly set nail heads when working without pulling out a hammer. So quick and easy.
One of the good things about these forums is that you get introduced to new things. I hadn't seen the Spring nail sets before in the UK. They look quite good from the videos so just ordered a set from a supplier over here.
Thanks for the info
A quick perusal of Amazon reveals many, many imitators & clones of the Stanley "softgrip" punches.  Imitation is not just flattery:  Stanley produced a winner here.
At 5" (125mm) they're usefully longer than most, as previously mentioned.  This makes them more forgiving of my occasionally inept useage.  I have a few, liberally scattered around my various tool boxes & belts as I've found them usefully robust, long-lasting & effective.  Some mushrooming of the head is inevitable, & the rubber? coating (usefully colour-coded in diameters) will eventually tear &/or wear.
Still, after some 20 years + of rough use, they've more than proved themselves.  I note that modern manufacture is now from east Asia:  don't know if that denotes any quality differences or not.  The modern iteration appear to be superficially different too.  About the only situation where the bigger (red) punch fails is in floor renovation.  Corroded handmade rectangular nails with elongated heads take more shifting for floor sanding prep than these punches can provide.  For this particular purpose I tend to use a much bigger (6"?), fatter & heavier (est x 5 or more) Finkal flooring punch that has sufficient toughness to withstand the pounding abuse of a 2 pound mini-sledge.
Spring tools are a user preference (I hate those things).
Starret makes nail set tips for their automatic center punch
(alhough, a bit time consuming for the application).
I may have a pb baumann, facom, or some german made nail set hiding
around with my drift punches.  Those and starrett are going to be the
best of the best.  PB Swiss being twice as good as the chart toppers (their punches are exquisite specimens).
Generally, the cheap Wilde 3 piece sets of sets I toss in the systainer with my brad and nailers do the job with no complaints.  $4 at Menards.
I don't like the tapered shaft on most nail sets.  It makes the hole bigger as you set the nail head below the surface of the wood.
RJNeal said:
That’s one reason RobBob that I use snap on punches.
Rick.
Yup, I have a Beta one for the larger nails I need to set and plan on getting a couple more, grinding a slight hollow in the end with a Dremmel so they go where I want them to better.
dmccririe said:
I like the spring ones too, but they go out on "permanent loan" more often
I hate when people like my tools more than I do [crying]
