Tom the Remodeler
Hi gang! Ok, so, recently I have been performing a lot of demolition work where I am cutting concrete, stucco, plaster, and sheetrock with an angle grinder with dust shroud, as well as sanding sheetrock, and chipping concrete with a Hilti TE-1000 and dust boot.
To date I've been using my CT-26 with an Ultimate Dust Deputy. The Dust Deputy certainly lives up to its reputation, filtering out 95%+ of the cementitious dust, but what does make it through eventually seems to saturate the pores in the Fleece Bag in the CT-26, leading to a loss of suction, even though the bag is only 1/8 full. Also, the CT-26/Dust Deputy setup is cumbersome to move around a job site.
I'd be happy to give the CT-36 AC a go, but I understand that Festool specifically bars it for use with cementitious materials, so the CT-36 AC is "out".
In another forum I've heard VERY positive reviews of the Starmix vacuums, which are apparently licensed to many other manufacturers, including Mafell, Metabo, and Bosch, among others. The Metabo flavor is distributed in North America, the ARS 35. This vac has HEPA filters that work in the AutoClean function, static-dissipating capability, OK for use with cementitious materials, variable suction, and can be fitted with a Systainer dock.
http://www.cpometabo.com/metabo-ars-35-1-400-watt-autoclean-wet-dry-vacuum/mtbnus602055800,default,pd.html?start=2&cgid=metabo-vacuums
Are there any other vacs I should be considering? Has Festool changed their stance on using the CT-36 AC with cementitious materials, or eventually certifying it HEPA?
Thanks!!
Thanks!!
