Patrick Cox
- Apr 25, 2016
Hello,
I am planning to build a rolling cart to rest my MFT3 table on. I plan to remove the legs and rest the top on this cart. I am using the plans originally posted by [member=14226]sprior[/member] . The cart will be built using 3/4" birch plywood and I will use Woodriver casters on the bottom..
WoodRiver Casters
The cart I am planning is shown in this thread... (the 2nd version.)
http://festoolownersgroup.com/membe...-come-up-with-version-2-for-this-mft-sysport/
Below is a sketchup drawing based on the plans included in the thread above. (The top is see through in this sketch.)
My question is - I am not sure of the best order of assembly of this structure and also where I need dominos. So for example, should I use dominos on all edges of the center divider wall or only on a subset of the edges? It seems that if I use dominos and all edges it will be difficult to assemble. And then again, in what order should I assemble the pieces?
Thanks for your comments!
Pat
WoodRiver Casters
Pat
