yetihunter said:
NIIIICE. Been running Bosch and Metabo 21700 battery packs; and, those two brands ain't got too much on Festool's cordless lineup; believe it or not. I'm praying that a torque upgrade to the T/C 18 drills will eventually follow suit.
Not very likely to see a torque upgrade since Festool has said that they are torque limited for wrist strain / ergonomic reasons.
The C18 is limited to 27/45Nm and the T18 is rated at a slightly higher 32/50Nm.
If they cripple the machine with RFC (reaction force control) they will be able to up them numbers but I personally prefer a drill that doesn't stop all the time. Bosch as well as Hikoki has RFC and I admit it works well for some applications but it is also a nuisance at times...
The DRC 18/4 is your best bet with 60NM torque. It comes with the extra handle so is "torque approved" but I almost never use the handle though it is nice for larger hole saws. I still have my DRC and it is plenty strong but I find the third gear a bit weak though useful for drilling. Grip is good and the LED is the best of the Festool drills and you can leave it on.
I use it with 3.1Ah batteries. Not too interested in the 4Ah batt's myself but eventually I might snag one or two. Those newer cells are better for sure though I don't really suffer with the 3.1Ah battery since I use them exclusively for the drills.
