I just received my new C15 today (at long last). When i opened the box i thought i would give the 2 battery's a full charge as i do with any new drill. I plugged the charger in & the light went yellow. Slid the battery in & it started flashing green bur after about 2 seconds it started flashing red [eek]. The instructions say this is to do with the temperature ! Both battery's were exactly the same & i left them for an hour & tried again but the same happened. Phoned my dealer but they did not know why this was happening.
I phoned Festool UK & they told me the battery's come fully charged & if you try to charge it then it will flash red. They say you cant charge it until the power level is below 80%.
I will run the batteries flat & then try to charge but i have never heard of this before, certainly never seen red flashing lights with my old C12 drill.
It does look a nice drill though with a lovely light [big grin]. The belt clip is quite cool, it is on both sides of the battery but you push it to one side or the other depending on what hand you use. Well thought.
Just wondered if anyone has had this issue with the red flashing light ?
Cheers, Woodguy.
Cheers, Woodguy.
