Woodchippie
- Mar 27, 2014
Thought I would test out my new Carvex this morning.
Inserted The supplied Carvex blade and followed the set up guide clamping the blade in the jaws with slight movement from side to side.
I have some softwood laminated stock 45mm thick, so gave it a try..not square at all a least 2-3 mm out of true.
I tried moving the block over,that the blade guides are attached to, only made slight difference.
Also tried some 18mm MDF and that's marginally out of square.
After seeing all the videos on YouTube, i was expecting better.
Is this human error...
Any suggestions would be welcome
