Approximately 2 month old CT MINI1 keeps cutting out after 5-8second long cuts.
5+seconds into the cut it just shuts down and the lowest suction light turns red.
Power off/on and it can fire back up but just cuts out again.
Plugged into its own 15amp outlet so it’s not sharing power on that circuit.
Cutting with the cordless TS55 so it’s not powering a tool.
Bag is empty, filter is spotless and great suction.
Also tried this on every power setting from Min to Max suction, no difference.
My only idea is that it might have to do with the Bluetooth remote I added on the hose end. I think it’s battery is almost dead because it fails to work half the time.
My curiosity is if the vac is set to shut down when the remote battery is dead? This would be pretty sad if it was made to disable the whole machine.
