usernumber1 said:
all the vacuums have a built in BT module looks like. ct26 lost the mechanical controls but is also AC now? the ct36 still has mechanical dials
Only the CT 26 ones on display were the "new" version, the FT employee actually used the "old" 36 and 48 for comparisons.
IMO this new CT 26/36/48 series version is a downgrade on almost all fronts.
- no manual controls
- no more upgrade option => no native air-control option, no native second socket option
- the "bolted-on" 2-socket contraption is extremely exposed hence unusable in practice, a clear band aid when test group screamed about the loss of the 2-socket option ..
+ beefed up front panel plate (was notorious for being broken by rough use)
+ no change in the form factor and the bins/bags/accessories system
The only real "positive" I see is the marketing checkbox that BT is now included by default. But skipping the "upgrade" slot is a far bigger issue that cannot be compensated by that. Worst, there was zero (technical) reason for that removal!
Overall, I rank this one as the second biggest botch-up by the "new gen" FT products team. Right after the Systainer heights desaster.
Thankfully, I landed myself a Protool CTL 48 AC HD recently to go along my CTM 36 AC. So probably set for life on the big vacs side. Just need to grab a 26 bin set to go along as I plan to keep the 48 bin dedicated to AC work.
