pingvinlakrits
- Oct 2, 2007
Got a text from the local Fess-Pusher and had the new CXS to collect.
Everything was as expected - though the battery is wider at the base. The advantage is that the CXS stands better, the disadvantage is that the CXS becomes a bit wider, approx 63mm at the base. It is not often you need to squeeze the CXS through that tight a gap so no concern there really. I like that it is wider at the base, it is really like a mini C15/C12 now.
Battery gauge simple but stays on long enough to gauge the status, three dots if fully charged.
New drill chuck is nice - still very light small but takes a massive 10mm over the old one which held a puny 8mm.
10mm is quite enough for this machine.
Battery attachment/insertion points do seem a bit fragile [blink] and the TXS/CXS battery does not extend into the C grip. It does not inspire confidence with the tiny latches but time will tell if it will hold up or not.
All in all, happy to have 2,6Ah batteries and expect a good run time with it. Also like the drill chuck. All the rest sort of feels the same. A bit disappointed that it isn't brushless but the last one lasted four years and if this one does maybe they will have a brushless version by then.
