- Jan 22, 2007
Festool USA has announced the expansion of its hand sanding line up, coming March 1st, 2017. Complete list of new additions at the bottom of this post.
Shop Festool Hand Sanding
Whether for those difficult-to-reach spots or for carrying out minor corrections, the new GRANAT premium hand sanding abrasives ensure you will achieve the desired sanding results quickly and efficiently, even for hand sanding. Long lasting, high-performance abrasives are resistant to tearing and are durable and washable. The synthetic resin bonding provides a tenacious grip for long lasting cutting power without grooves or scratches. Specially formed sponges provide unique profiles tackle hard-to-solve hand sanding problems, and sheets and rolls, tackle common sanding needs.
Abrasive Block
4-sided and the grit is dimensional stable for sanding in one operation two sides of the workpiece. Exceptional longevity of the the block due to the medium-hard foam core. The combi block with it round side and 45 degree edge allows you to get into those hard to reach places.
Abrasive Sheets and Rolls
Flexible and universal hand sanding abrasive for paint, putty, filler, lacquer (VOC-lacquer and hard materials).
Benefits
• Longer service life and a high material removal rate due to special fused aluminum oxide.
• Synthetic resin for entirely bonded grits delivering long lasting cutting power.
• Due to the unmatched grit bonding you will have less grid brack out when folding or adopting to your surface
Abrasive Block
Benefits
| Item No. | Description | Price |
| 201080 | Festool Granat Abrasive Sanding Block, 36 Grit, 6-Pack | $22.00 |
| 201081 | Festool Granat Abrasive Sanding Block, 60 Grit, 6-Pack | $22.00 |
| 201082 | Festool Granat Abrasive Sanding Block, 120 Grit, 6-Pack | $22.00 |
| 201083 | Festool Granat Abrasive Sanding Block, 220 Grit, 6-Pack | $22.00 |
| 201084 | Festool Granat Concave Sanding Block, 120 Grit, 6-Pack | $22.00 |
| 201085 | Festool Granat Abrasive Sheet, 40 Grit, 25-Pack | $18.00 |
| 201087 | Festool Granat Abrasive Sheet, 60 Grit, 50-Pack | $36.00 |
| 201088 | Festool Granat Abrasive Sheet, 80 Grit, 50-Pack | $36.00 |
| 201089 | Festool Granat Abrasive Sheet, 100 Grit, 50-Pack | $36.00 |
| 201090 | Festool Granat Abrasive Sheet, 120 Grit, 50-Pack | $36.00 |
| 201091 | Festool Granat Abrasive Sheet, 150 Grit, 50-Pack | $36.00 |
| 201093 | Festool Granat Abrasive Sheet, 180 Grit, 50-Pack | $36.00 |
| 201094 | Festool Granat Abrasive Sheet, 220 Grit, 50-Pack | $36.00 |
| 201095 | Festool Granat Abrasive Sheet, 240 Grit, 50-Pack | $36.00 |
| 201096 | Festool Granat Abrasive Sheet, 320 Grit, 50-Pack | $36.00 |
| 201097 | Festool Granat Abrasive Sheet, 400 Grit, 50-Pack | $36.00 |
| 201099 | Festool Granat Abrasive Sponge, 500 Grit, 20-Pack | $36.00 |
| 201100 | Festool Granat Abrasive Sponge, 800 Grit, 20-Pack | $36.00 |
| 201101 | Festool Granat Abrasive Sponge, 1000 Grit, 20-Pack | $36.00 |
| 201102 | Festool Granat Abrasive Sponge, 1500 Grit, 20-Pack | $36.00 |
| 201103 | Festool Granat, 40 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201104 | Festool Granat, 60 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201105 | Festool Granat, 80 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201106 | Festool Granat, 100 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201107 | Festool Granat, 120 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201108 | Festool Granat, 150 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201109 | Festool Granat, 180 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201110 | Festool Granat, 220 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201111 | Festool Granat, 240 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201112 | Festool Granat Abrasive Sponge, 60 Grit, 6-Pack | $10.00 |
| 201113 | Festool Granat Abrasive Sponge, 120 Grit, 6-Pack | $10.00 |
| 201114 | Festool Granat Abrasive Sponge, 220 Grit, 6-Pack | $10.00 |
| 201256 | Festool Granat Abrasive Sheet, 40 Grit, 10-Pack | $9.00 |
| 201257 | Festool Granat Abrasive Sheet, 60 Grit, 10-Pack | $9.00 |
| 201258 | Festool Granat Abrasive Sheet, 80 Grit, 10-Pack | $9.00 |
| 201259 | Festool Granat Abrasive Sheet, 100 Grit, 10-Pack | $9.00 |
| 201260 | Festool Granat Abrasive Sheet, 120 Grit, 10-Pack | $9.00 |
| 201261 | Festool Granat Abrasive Sheet, 150 Grit, 10-Pack | $9.00 |
| 201262 | Festool Granat Abrasive Sheet, 180 Grit, 10-Pack | $9.00 |
| 201263 | Festool Granat Abrasive Sheet, 220 Grit, 10-Pack | $9.00 |
| 201264 | Festool Granat Abrasive Sheet, 240 Grit, 10-Pack | $9.00 |
| 201265 | Festool Granat Abrasive Sheet, 320 Grit, 10-Pack | $9.00 |
| 201266 | Festool Granat Abrasive Sheet, 400 Grit, 10-Pack | $9.00 |
| 201507 | Festool Granat Abrasive Sponge, 800 Grit, 6-Pack | $10.00 |
| 201768 | Festool Granat, 320 Grit for Hand Sanding, 80ft Roll | $46.00 |
| 201769 | Festool Granat Abrasive Sponge, 280 Grit, 20-Pack | $36.00 |
