New from Shaper Tools: Connected Caliper and Edge Mortising Adapter
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Check out these new releases from Shaper Tools!
Shaper Tools Connected Caliper - $220.00
This high precision caliper not only captures accurate measurements, it automatically sends measurements to Origin with the press of a button, covering dimensions from cut depth to part geometry. Its Bluetooth connectivity allows seamless transmission to computers, facilitating integration with CAD tools or spreadsheets. The Connected Caliper is the go-to solution for guaranteed accuracy in workshops, job sites, or any location requiring precision.
Shaper Tool's Edge Mortising Adapter - $129.00
Expand the functionality of the Shaper Plate. The Plate simplifies the installation of hardware and other portable cutting operations, and the Edge Mortising Adapter enhances the versatility of the Plate, enabling vertical workholding or work on an edge. Shaper Tools Edge Mortising Adapter is attached to the Plate's base in any of three positions to establish a reference face and clamping surface. It can be easily aligned, installed and removed. Its die-cast aluminum construction makes it lightweight and durable.
Shop Shaper Tools Today!
six-point socket II said:
That caliper is cool!  [thumbs up]
Kind regards,
Oliver
Ya, that's thinking outside the box...digital calipers have been available with SPC outputs for the last 30-40? years, but they were always connected with a cable and inputed the data to a data collector/buffer or data logging software.
Now, you've eliminated the cable through BT and input the dimensional data directly to the Shaper tool...slick.  [cool]
  • EC799:B.jpg
