New Laguna V:10 Bandsaw - Compact and Powerful
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Rethink what you expect from a 10-inch bandsaw. The all-new Laguna V:10 is packed with features normally found only on larger machines, making it the most capable 10-inch woodworking bandsaw on the market - perfect for small shop or as a precision saw to complement a larger saw.
  • Exceptionally smooth and stable: Featuring cast iron wheels (the only 10-inch saw with this feature), the V:10 gives you exceptional stability and smooth blade tracking.
  • Excellent visibility: The integrated LED work light and built-in 120V outlet for additional lighting keeps your work area well-lit. Dual dust ports and thru-table extraction helps keep the area clean. Resaw up to 5.75 inches with the 1 HP induction motor, so you can take on bigger tasks with this compact saw.
  • Engineered for precision: The V:10 comes standard with easy-to-adjust micro-adjustsable roller bearing blade guides, a hi/low fence with solid steel rail for precise cuts, dual blade tracking windows, a quick-release blade tension lever, and two blade speeds for ultimate control.
Take your Laguna V:10 Bandsaw even further with purpose-built accessories designed to enhance versatility and efficiency:
Compact, feature-rich, and built for serious performance, the Laguna V:10 delivers professional results in a space-saving package.
Pre-Order Now
The only problem with a small BS such as this is breaking the band because of the small wheels. There have been three-wheel BS's made in the past in an attempt to overcome the issue but for some reason they have never been big sellers. Always use very thin bands on small saws such as this and consider them consumables if they break.
I owned a 3-wheel Inca 710 bandsaw with riser block some time ago. It's hard getting all 3 wheels aligned well. I sold it and got a big 540mm Italian bandsaw that I still use today.
