new ro 150 feq does not work
rich sdr
I just have a new festool ro 150 feq
In short
Open the box, get the festool out, then i plugged the power cable
Then push button forward and nothing happend.
I checked the cable for power with screw driver and there is power on it
I think the machine is not working but you can not check this (warranty)
Or is there something else
Are you sure you put the cable in properly? With a new cable it can be that you have to twist it in very firmly.
If that's not it, then contact your dealer and get a replacement/repair.
Once you install the cable - which will be tight- push in and turn a full 90 degrees clockwise.  If that doesn’t help contact your dealer and return for a replacement.
In short
If you can pull the plug it cord out without twisting, it isn’t seated. Like others said, push it in and twist a quarter turn clockwise.
I also am a little curious as to testing power with a screwdriver but let’s tackle that another day.
Cheers. Bryan.
I've never seen a screwdriver style circuit tester for anything other than low voltage...from around 3-40 volts.  [tongue]
That type of testing screwdriver is common in the UK for testing 240V.  Neon and resistor in the handle.
