- Jun 25, 2016
[size=18pt]Looking for higher quality guide rail clamps? We're excited to now offer three new styles of guide rail clamps from Axminster, each offering a lifetime guarantee. Beyond their fantastic feel and "heft," these clamps are resistant to slippage and each feature a specially designed head that fits into the slot on the underside of your track saw guide rail to prevent the guide rail from moving—ensuring more accurate cuts. These clamps are compatible with Festool FS, Makita, Milwaukee, DeWalt, Kreg, and Rigid guide rails.
Shop Guide Rail Clamps
What else is new at TSO?
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
JUST RELEASED! MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check our our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
GRE-13 Guide Rail Extension
Provide more support at both ends of your plunge cuts with this 13.7-inch (346 mm) guide rail extension, which conveniently fits in a Systainer. Connectors included!
