- Feb 22, 2016
Just getting started with this. Some quick background info.
We lost our smart TV to a nearby lightning hit 2 weeks ago. After finding out it wasn't cost affective to repair we found a same size screen replacement. Difference is the old TV had a pedestal base in the center and all the new TVs that we found have a pair of legs at each end. There is the problem, those legs are out at the VERY end, like 64 inches apart. The TV console is only 60 inches wide, so not wide enough to support any of the new TVs.
So I said I'll make a new, wider top for the console we have now. The existing is made from steel frame with ~3/8" thick plate glass shelves and top. The top is one piece of glass 24" x 60" and is secured to the frame at each corner with a bolt that goes through a hole drilled in the glass and connects to a post.
My plan is to replace that top glass with a slab of wood with a live edge along the front. The slab with be a slight trapezoid shape, 64" across the back and 72" wide across the front, so a slight angle on each end.
I have a slab of Cedar 2.5" x ~23" x 74".
Well, looks like a serious lightning storm is upon us right now so I'll have to finish this later.
Time to unplug, photos coming.
