New Truck Build
reddevil
At work we have received a new truck.
[attachimg=2]
[attachimg=3]
This is a proto type of a slide. The trays in it are also homemade. There are 6 standard sizes.
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
[attachimg=8]
I like that
What is the material and what are the sizes ?
And also how do the boxs relate to the van
Making the sliders. There is a high and low model, just as the trays.
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
They are made of 4 mm thick marine plywood or form plywood (I don't know the English name right, I come from Belgium). I make them from that material so that they are watertight. That's on the work sometimes necessary
Dimensions are; height  5.2 cm, width 10 cm, length 10 cm, 15 cm or 20 cm low model and height 10.4 cm, width 10 cm, length 10 cm, 15 cm or 20 cm high model.
They are going to be used as stokage in the truck.
We are once again a little further.
[attachimg=2]
[attachimg=3]
[attachimg=4]
After a day building is the most done.
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
I'm building a small water reservoir
[attachimg=2]
[attachimg=3]
[attachimg=4]
Hooks for power cables and compressed air.
[attachimg=5]
A cart for the miter saw, It is easier to handle.
[attachimg=6]
[attachimg=7]
[attachimg=8]
[attachimg=9]
waho6o9 said:
I think it's a table saw and chop saw combo.
It is a combination miter saw, table saw.  Unfortunately, as far as I know they are NAINA (see it's not just Festool that does that)
Ken
With the warm weather coming,I built a small fridge in the truck. He runs on 12V or 230V.
[attachimg=2]
[attachimg=3]
[attachimg=4]
Taking time to set up your vehicle is commendable . every detail matters.
A little progress.
Special drawers
[attachimg=2]
[attachimg=3]
Power distribution, i can also read the voltage and current. it have also two compressed air connections. It provides power to the entire truck.
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
Work light
[attachimg=8]
[attachimg=9]
A small workbench
[attachimg=10]
Length stop for miter saw
[attachimg=11]
[attachimg=12]
[attachimg=13]
[attachimg=14]
[attachimg=15]
Some very impressive stuff there! I especially like the latch you made for the drawers. I might steal this idea for the drawers in my truck.
Good work.
We do almost everything from the building. Plumbing, heating, electricity, tiling, bricklaying, roofing, excavation works, drywall,steel structures, wood structures, ......
This is in renovation and new construction that we are doing the work.
Latest project, a concrete basement.
Reddevil, nice truck setup! On your small workbench you have some Dewalt stand brackets I haven't seen before. Are they to mount a tablesaw or planer to the Dewalt stands? Can you give me they're Dewalt item number?
Cheers
Curt
