New TSO Product: Doggone Great Storage for Your 20mm Bench Dogs
TSO_Products
Retailer
Introducing the TSO Bench Dog Rack: the ultimate home base for your 20mm dogs! This blue anodized aluminum rack keeps up to eight bench dogs securely lined up along the side of your Festool MFT/3 or Dashboard PWS table. No more runaway dogs or cluttered workbenches—this rack keeps your tools at attention and your workspace clear. Designed for compatibility with 20mm bench dogs from TSO, UJK, and more, it’s as stylish as it is convenient.
[size=18pt]Shop the TSO Bench Dog Rack
What else is happening at TSO?
JUST RELEASED! MFT/3 Router Table Extension
Simplify your workflow with a router table extension purpose-built for the MFT/3. The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support, helping you maximize your workspace and productivity. Compatible with the most popular trim routers on the market.
JUST RELEASED! MFT/3 Extension Table
Expand your Festool MFT/3 work surface by 33%! This extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories.
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
