New TSO Product: Narrow Stock Pro Rip Cutting System for Track Saws
TSO_Products
Retailer
Track saws are incredibly versatile tools—but when it comes to cutting narrow stock, the setup can get a bit tricky. Without support under the guide rail, there’s a tendency for it to sag or tilt under the weight of the saw, especially at the beginning and end of the cut. And when your workpiece is narrower than the guide rail itself, it can be difficult to register a precise, repeatable cut. TSO's Narrow Stock Pro addresses both of these challenges with one compact system comprised of two Guide Rail Supports to prevent deflection or tipping, and two precision Gage Bars that extend under the rail to form a reliable fence for narrow rip cuts.
Available as a Complete Set (2 Gage Bars and 2 Guide Rail Supports) or Gages Only (2 Gage Bars). The Guide Rail Supports are also available separately (as pairs), and make a nice addition to any track saw setup.
Shop the Narrow Stock Pro & Accessories
What else is happening at TSO?
Multifunction Workbench Fence & Stop Set
Featuring laser-engraved imperial plus metric scales for exceptional accuracy, a robust dual-arm flipstop for reliable and repeatable cuts, and a versatile design that can be mounted upright or flat to suit your needs. Made in the USA from 6061 aluminum with a durable blue anodized finish, the TSO Multifunction Fence installs quickly onto the Festool MFT/3® or any worktop sharing the popular 20x96mm hole pattern.
MFT/3 Router Table Extension
Simplify your workflow with a router table extension purpose-built for the MFT/3. The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support, helping you maximize your workspace and productivity. Compatible with the most popular trim routers on the market.
MFT/3 Extension Table
Expand your Festool MFT/3 work surface by 33%! This extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories.
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
Just placed my order for the narrow rip guide...I cannot wait as I have been wanting a simple system like this for years!!!
Looks like a great solution to solve what many consider the biggest challenge for a track saw. While looking at the solution I started wonder how wide does the board have to be to not slip under the rail without tape or something else to hold the board in place?
