New TSO Product: Upgraded Rip Fence for SawStop CTS Compact Table Saw
TSO_Products
Retailer
We’re expanding our lineup of upgraded rip fences once again—this time for the SawStop CTS Compact Table Saw! Following our precision fences for the Festool CSC SYS 50 cordless saw, DeWalt jobsite saws, and Milwaukee M18 FUEL table saws, this new model brings the same features and accessory versatility to the CTS platform. Machined from clear-anodized aluminum, it adds three integrated T-slots—two on the face and one on top—for mounting JessEm Clear-Cut™ FLEX Stock Guides, featherboards, sacrificial fences, and custom jigs. Installation is straightforward, reusing the CTS’s existing brackets and hardware while preserving all of its original functionality.
Shop the Upgraded Rip Fence for SawStop CTS
What else is happening at TSO?
JUST RELEASED! Parallel Guide System Gen 2
Transform your track saw into a precision panel saw capable of repeatable, cabinet-saw-quality cuts. Compatible with Festool, Makita, Milwaukee, Kreg, Ridgid, Powertec, and WEN guide rails, it combines single-piece aluminum tracks, innovative new Drop-Loc Connectors, and Flip Stop Pros for fast setup and uncompromising accuracy. Available in 20", 30", and 50" capacities, Gen 2 delivers unmatched repeatability and versatility for everything from drawer parts to full-size panels.
Multifunction Workbench Fence & Stop Set
Featuring laser-engraved imperial plus metric scales for exceptional accuracy, a robust dual-arm flipstop for reliable and repeatable cuts, and a versatile design that can be mounted upright or flat to suit your needs. Made in the USA from 6061 aluminum with a durable blue anodized finish, the TSO Multifunction Fence installs quickly onto the Festool MFT/3® or any worktop sharing the popular 20x96mm hole pattern.
MFT/3 Router Table Extension
Simplify your workflow with a router table extension purpose-built for the MFT/3. The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support, helping you maximize your workspace and productivity. Compatible with the most popular trim routers on the market.
MFT/3 Extension Table
Expand your Festool MFT/3 work surface by 33%! This extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories.
GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
