I'm a hobbyist and newcomer to the Festool family and just got the ct mini with rotex 90 for a project with some reclaimed wood. Prior to the rotex 90 I was using a Makita 4-1/2" ROS.
When sanding down the exterior of my reclaimed wood planks, I attached an 80 grit granat and put the rotex in rotary mode and started at speed setting 1. I noticed that the torque was really high which impressed me but at the same time that made the tool hard to control. It seemed to have a mind of its own and I had difficulty getting it to go where I wanted it. I felt I was wrestling the tool and that tired me out. I tried setting the speed to 2 but that didn't help much with controlling the tool.
Also I found it difficult to keep the tool flat on the wood. I might just not be used to working with such a small radius disc. I felt like I was making lots of gouges into the wood. I have however read from the forums how to hold the tool and I am keeping one hand wrapped over the power cable and anti-static hose and the other hand over the green setting dial (where you control rotary, random orbit or delta mode). I am applying slight downward pressure over the sanding surface but like I said above it's very difficult to keep it flat and going where I need it to.
I've read great things about the rotex 90 so I'm sure I must be doing something wrong or my technique is bad. Either way I hope the experienced pros can offer some advice. Thanks.
