New Woodpeckers OneTIME Tools Dado Set-Up Fixture and Gap Gauges
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Order deadline is Monday February 19th at noon. You must pre-order to get these items. Delivery is scheduled for May 2024.
Woodpeckers' Dado Set-Up Fixture and Gap Gauges are tools designed to make the process of setting up a dado blade on a table saw easier, safer, and more convenient.
The Dado Set-Up Fixture streamlines the setup of a dado stack by making it easy and convenient to build and adjust it at the comfort of your workbench instead of inside your table saw. With the Dado Set-Up Fixture, you don't risk damaging a tooth or dropping a blade into your tablesaw as you build and adjust the dado stack. Once the right combination of shims and chippers has been established, it's simple to transfer to the table saw.
The Gap Gauges help in achieving a precise fit by providing a reference for the correct width of the dado. They directly gauge the stock, then are used to transfer that measurement to the dado stack.
Purchase the Dado Set-Up Fixture, Gap Gauge, and Mini Gap Gauge separately or in a cost-effective set.
Pre-Order Now!
