tenfingers
- May 20, 2008
So last night I got everything set up, but not fired up as it was midnight before I could
get out to the garage (honey-do-list). Nonetheless, I did fire up the domino and put in some test mortises
into scrap plywood. I've also read Jerry Work's manual, which did help (vs. the manual)
Question: to make a tall bookcase, I'm planning on using domino joinery for the top and bottoms using top
and bottom pieces' edges to side faces. I am going to put a middle fixed shelf in with a dado. This way I can reference
my hole boring 42" guide off the middle dado to do the top holes. Now, would domino joinery be strong enough for
approx. 29 inch shelf of textbooks? (if i decide to do middle shelf with domino?)
Thanks,
Martin
PS - yet to fire up the TS55 and OF 1400, but excited
PPS - I tried as hard as I could to see a fleck of dust while sanding with my ETS 150/3 and when using the domino. Where'd it go?
Thanks,
Martin
