Happy new year and hello from something of an imposter - I don't own any Festool kit, heck, I'm not even a craftperson / maker / tradesman, but I am a hobbyist designer. I'm currently planning out a cabinet in Fusion 360 that will be largely fabricated by a flatbed CNC router, but there are butt joints where I wish to employ the strength and minimal appearance of the Domino loose tenon joints. Mortices in board faces will be cut by the CNC, but mortices cut on the panel ends will have to be done with a Domino cutter as the flatbed router can't machine these faces.
I'm trying to make this 'hand' machining element (everything off the CNC) as simplistic as possible and one of the big attractions of domino joints is the ability to standardise the inset from panel ends with the use of the fins/pins. Here is my first question - is the dimension from the pin to the cutter centreline 37mm? This is what I have read, but it would be good to have it confirmed.
Secondly, can someone help me understand how the height of the mortice is set? As I understand it, if cutting in to the end of a board, the workpiece is layed down flat and the domino either rested on the same surface - with the cutter ending up 10mm to centre up the thickness of the workpiece;
or it's suspended in air with the fence flat on the upper face of the workpiece and the thickness of the material (either 18 or 19mm in my case) set on the fence material thickness setting.
In this latter case does the cutter end up exactly half way up the material thickness? (9/9.5mm for a 18/19mm setting)
I assume the latter is the most accurate as you're not replying on the flatness of the worksurface but rather using the Domino fence as the datum, although perhaps requires a little more user skill?
If all this info is freely available somewhere please feel free to point it out to me. I had a look in the manual, but could see any mention of these figures. Thanks in advance for any help.
