Obtaining Unusual Angles with Precision
smorgasbord
NorCal
An old review of a protractor devolved into a discussion of how to obtain non-standard angles (which are 22.5º, 30º, 45º, 60º nor 90º) with a high degree (pun intended) of accuracy. I'm moving that discussion to its own thread here.
There are various digital angle "finders" available, but their accuracy is at best +/- 0.1º. Most are worse at +/- 0.2º. For some purposes, that may be accurate enough, but for others, such as making a wide pentagonal frame, even just 1/10º off means there's a full degree of gap in the frame. And while trial and error techniques can enable us to sneak up on accurate angles, or the use homemade guides/templates that are flipped to remove the gap at the price of a small misalignment, there are some projects (tapered boxes is the obvious one), where those techniques can be difficult. Note that the digital inclinometers currently favored by YouTubers also have accuracy of only +/-0.2º - worse than the better finders (protractors).
Before John Economaki retired and sold Bridge City Tool Works to Harvey Tool, he made two versions of an "Angle Master Pro" device that used a caliper to dial in (pun intended) accurate angles. The AMPv2 was reviewed by [member=3513]PaulMarcel[/member]  here (blog and video). The AMPv2 sometimes shows up second hand for about $300 or so, but that's rare and even then, expensive.
I was pointed at the Shinwa Sliding Bevel by [member=74278]Packard[/member]. Like the AMPv2, it uses the Law Of Cosines to produce angles based on the length of 3 sides of a triangle. I bought the largest one Shinwa makes on Amazon for about $60. Here's what it looks like:
I don't have an uber-accurate way to measure angles where I'm at right now. For grins, I've been playing around with the Shinwa, a Wixey digital finder, my old AngleWright (also not made, probably accurate to 1/10º at least but not much better), and a DIN-rated square. Here they are nested at 40/50 degree angles (not a good way to test, though):
[attachimg=2]
For $60, the Shinwa seems pretty good for angles between about 20º and 120º (the closer you get to the middle the more accurate it seems to be). But, it seems to be made for carpenters cutting rafters and such - it can be used like a larger, more accurate speed square to guide circular saws cutting 2X lumber.
But, the design using the LOC (Law Of Cosines) has much more accuracy potential. One problem is that, due to the cosine function, the angle markings along one arm are not evenly spaced. This makes obtaining angles like 43.7º difficult since you have to interpolate 7/10 of the way between 43º and 44º. Now, there is a metric scale along the top edge that can help with interpolation (as [member=74278]Packard[/member] pointed out), but an even more accurate procedure would be to use a large caliper from the far end, then do a subtraction to get the effective arm length to plug into the LOC formula. Here's a demonstration of that setup for a 42.77º angle:
[attachimg=3]
Essentially, instead of using the metric scale on the Shinwa, use the depth rod on the caliper to get a more exact reading.
[attachimg=4]
versus
[attachimg=5]
To do this, I had to first measure the Shinwa's two fixed-length arms. This is done between the center of the pivots, since the arms are parallel to the centerline between the two pivots. The fixed middle arm is 330.0mm long, the fixed side arm is 291.0mm (as best I could measure). For the adjustable side there are a couple complications, but not too bad actually. First is that we're measuring not from the pivot but from the far end of the arm. The arm is 640.0mm from pivot to the end (as best I could measure). Second is that Shinwa uses a plastic indicator that slides in a groove along the arm, trapping the pivot and providing an edge against which to line up with the markings. I measured the distance from the edge to the center of the pivot hole at 17.5mm. Thus, the effective length is 640.0 - 17.5 = 622.5 mm.
Now we can use the LOC to get the effective length needed, which we subtract from 622.5 to obtain our caliper reading.
The example in the photos above is for 42.77º. Plug in 291.01 for side a, 330.0 for side b and 42.77 for Gamma (the angle), and side c is 477.91 mm. We subtract that from 622.5 since we're reading from the other end, and you get 144.59mm. Slide the plastic indicator against the caliper depth rod until you get that reading, and viola! you're at 42.77º. Which checks out as far as I can measure, which isn't nearly good enough unfortunately.
In evaluating the Shinwa, the plastic indicator appears to me to be its achilles heel. There's some play in the pivot hole, not quite a mm's worth. When using it to measure an existing angle, you can easily slide the plastic left or right a bit intentionally without changing the arm's angle. That said, with 42.77º needing 477.91mm, a +/- 0.1º (same as the best affordable digital finders) gives you a range from 477.29mm to 478.54mm, which is more than the play I observed. And then factor in that if you just use the indicator without trying to push it, it gives the more nominal/consistent reading (like using a SCMS without trying to push left or right), this already seems better than the digital angle finders.
I don't have a digital printer, but perhaps the next step is 3D printing a new plastic indicator with tighter tolerances.
Compared to the AMPv2, the Shinwa isn't as accurate due both to the play and due to it not being manufactured to high tolerances. Shinwa does a good job and for the money it seems to be good, but the arms aren't lapped for parallelness, nor the holes precision drilled (I didn't observe any play in the pivots though), etc. But, at this large size (60cm size), small differences shouldn't matter much, practically. Since on always has to transfer the angle from the thingie to the cutting tool, there's all sorts of possibilities for introducing error, from bevel alignment against the tool, to the tool itself (like a blade body that isn't perfectly flat or a miter fence that isn't flat or has some play itself, etc.). So we'll never achieve perfection, but I do like trying to eliminate as much potential for error as practical.
Also, the AMPv2 can be used directly to set table saw blade tilt angle, or miter gauge fence / miter saw angles, etc, whereas both the size and configuration of the Shinwa make the blade tilt angle particularly hard to do. You'd end up setting a regular bevel gauge against the Shinwa and then use that against the blade.
What's next here? I see three paths:
1) Design a new plastic indicator in Fusion360 and get it 3D printed.
2) Build my own version of the Shinwa out of aluminum or Delrin. I could build a large one to integrate into a miter sled, as well as a small/medium sized one to set bevel gauges against for blade tilt angles.
3) Woodpeckers makes a $330 Adjustable Track Square that's used like the clamp-on right angle squares, but has a protractor for angles. Chinese knock-offs are about $70. And TSO has their $470 MTR-18 Triangle that can accurately set 15º, 22.5º, 30º, 45º, and 90º angles (and complements) for direct track saw cutting as well as marking, probably a few other uses, too. But for the "unusual angles" you lose the accuracy.  I might play around to see if I can design a completely different adjustable track square that uses the LOC principle for better accuracy for all angles at a far lower cost.  Hmmm.
BTW, I did compare my Wixey to my DIN rated square, DIN rated 45º reference, and iGaging 45º bevel. The Wixey measured the 45º reference and iGaging bevel at 45.0º multiple times, but with the 90º square one direction of Wixey arm rotateion gave me 90º but the other direction gave me 90.1º sometimes. It's kind of a pressure thing, too - how hard I press the arms against the reference. Of course, that's not normally how one measures angles, seeking the value you want to get, lol. I'll have to do more to see if it's consistent that one direction of rotation is "better" than the other, or whether it's just slightly different one way and the DRO rounds up/down differently depending on direction, or whatever.
Also, I haven't yet measured the Shinwa against the 90º square. There are two ways I can do this - one is to set the Shinwa at 90º and with backlight look for light gaps when held against the reference. The other is to use the Shinwa to measure the inside of the reference and see what the reading is. The latter is not what the Shinwa is designed for, and with the indicator play, might not be proper.
Finally I know that this kind of precision exploration is not for everyone, and may not even be applicable for almost all woodworking. But, some woodworkers are already spending $300 and up for accurate "normal" angle cutting, so looking at cheaper ways that are more flexible or more accurate seems worthwhile to me.
Actually, with 3D printing *), the more practical approach is to print the exact angle needed as a one-off. Any adjustable square from PETG or so will have issues with the joints while the cost of material for a one-off is in the $1 range which is absolutely doable.
*) assuming one's printer actually prints orthogonal - a BIG IF, most FDM printers are within 0.2-0.3mm off from orthogonal, fine for FDM, not so much for making precise squares .. but that can be checked with a highly precise square and the 3D design corrected for any skew introduced by printer.
Maybe a silly question, but if you need this level of accuracy, then why not use a protractor with a vernier scale? That way you can have repeatable accuracy of up to 2 minutes (1/30°). Starrett and Mitutoyu have them. I am sure other brands will have cheaper versions that go up to 5 minutes of accuracy (1/12°). Even that should be enough for most tasks in a woodworking shop. Or am I missing something?
Something I've learned over time is, when real precision is needed, not to measure anything. Machinists learn this in the womb. Case in point is stacking up gage bars or using a story stick. For angles:
1 degree thru 30 degrees, use them to set your protractor device then transfer from there.
RMW
You can also draw a full-size drawing of the part, using an online triangle calculator (there are several).
Then use the drawing as a measuring tool.
With a sharp pencil and accurate rulers , you can probably be able to achieve gereater accuracy than the Shinwa.
Or you can use that drawing to check the Shinwa for accuracy.
I have no idea what level of accuracy that can be achieved that way, though.
RMW
Our QC manager had a set of those triangles.  Amazingly smooth and flat, stacked they held together like magnets.
But I have only seen him using these on a granite flat stone.  Most people that do wood working don’t have a 400 pound granite flat stone.  How do you use these?
This seems like a place for Woodpeckers and their manufacturing processes with stainless, aluminum, and laser engraving.  But maybe the BCTW version is good enough that it's not worth risking the IP infringement?
I would check the Shinwa unit against 30, 45, 60, and 90 degree angles on quality drafting triangles.
If the adjustable Shinwa unit is accurate against all four angles, I would trust it for the intermediate ones.
An amusing story only about 22.5 degrees off-topic.
In the late 1970s through the early 1980s, I was an independent sales representative. One of my principals produced large weldments.  Some as large as a room.
Brookhaven National Laboratories was by far my largest account.  We were asked to produce a robust “table” made from 3” x 4” heavy walled steel tubing.  Pretty straight forward except that it was 30 feet long and about 8 feet wide.
The kicker was that there was to be a small metal plate welded to opposite ends of the 30 foot length.  They had to be parallel with 0.005”.
So we produced the frame, mounted it on heavy (rail road tie) Timbers so that it would not be damaged in transit.
We rented a surface grinder that mounted to steel with magnets.  We hired someone with a transit to measure the parallelism.  (I was not there and my mind stalls each time I try to figure out how that was accomplished.)
We delivered it with our own flatbed truck.
I visited after it was set up.  At one end was mounted a laser, at the other end a mirror.
The amusing part was that both the laser and the mirror were mounted to a plate that allowed about 1/4” of angle variation.  Probably that would read at 10 to 20 degrees.
When I asked why they put that tolerance on the table, the engineeer said, “Well, I made the drawing and I had to put tolerances on it.”
It was a $20,000.00 project and at least half of that cost was the tolerance requirement.  A total waste of money and time.
The point being, tolerances should be given serious thought before implementation.
Post Script:  Ronald Reagan, the President at that time, decided that the DOE (Department of Energy) was no longer needed.  He shut it down.  Brookhaven Labs was part of the DOE.  I did not have the energy to build my business back up a second time.  I took a job with one of my Principals who had been offering me the sales manager job for several years.
RMW
When needing as close to 100% accuracy the machinists know the method that guarantees accurate results.
I'm not 3D printing a new LOC-based gauge, just a new plastic indicator piece to use with my existing Shinwa unit - one that has less play in the pivot hole. As you point out, both the materials and the accuracy of affordable 3D printers limits doing a new gauge. As for a one-off, I suppose one could calibrate their affordable 3D printer like I can calibrate my affordable CNC router, and I may investigate doing that to create one-off angle references similar to the one's Paul Marcel used in his "Angle Madness" project.
The 1/12º accuracy isn't much better than the 1/10º (both +/- I assume) I can get with the Wixey digital or my old AngleWright. Again, for a pentagon I could end up with a 1º error to fix (2 cuts per joint).
What's the price and usability of the 1/30º versions? More than $400?
I have such a set, but they're good for whole degrees only. Can't do my 42.77º example, for instance. And their size makes them more useful for blade bevel angles than miter angles. But even there, one has to be careful that your table saw insert plate is really coplaner with your table saw top - most aren't exact. Woodpecker's has a $200 set of gauges ("normal" angles only) that are wide so you can support them on your saw's top and not the insert, and they come in two heights: one for 10" blades and one for 12" blades. Seems like a good, if expensive, way to set tablesaw blade angles if you only need the "normal" angles.
I do have a 11"x17"x4" thick granite stone that I bought decades ago to use with my AngleWright, which is limited to the range of 45º to 90º. It doesn't have any calibration certificates, and it's been a long time since I backlit compared against by BCTW and Starrett straightedges. I'll do that once I'm back in the shop again (this angle exploration is keeping me busy while I'm away).
How do I perform this check? Stack the 30º drafting triangle with the Shinwa at 60º and fit both inside my reference square to look for gaps? That's going to be a difficult balancing act, and depends on the accuracy of my square. Also, chaining references sums the tolerances therein, which is why those angle and gauge blocks need to have more accuracy than you need.
For instance, getting to 38º means stacking a 30º block, a 5º block, and a 3º block. If each is accurate to, say, +/- 20 seconds, Amazon link, then result is accurate to +/- 1 minute. In practice, probably better since it's unlikely each piece is off by the maximum amount in the same direction/manner, but still. And 1/60º is good enough for my purposes.
Another way would be to set my sliding bevel against the Shinwa and use that to compare, which probably introduces some potential error, but would be how I use it in practice for tool setup.
Packard said:
An amusing story only about 22.5 degrees off-topic....
A real life Spinal Tap StonedHenge issue!
To check accuracy, I would use a draftsman’s triangle (a fairly large one—with 10” - 12” hypotenuse).
I would draw the two lines capturing the angle you wish to check.
I would use a straight edge to extend those lines.
I would rest the Shinwa on the drawn angle.
Depending upon the precision in which the lines are drawn, this should give an accurate angle to check against.
You could check, by adding the third side of the triangle and checking the measurements against those that the triangle calculator supplies.
I don’t own the Shinwa, so this method works in my mind—perhaps not as well in actuality.
I would note that there is a tendency to accept digital readouts as more accurate than than analog readouts.
We had a Ohaus triple beam scale that measured in grams in our office.  The owners son bought an expensive digital scale.
The Ohaus scale came with reference weights that allowed us to zero-out the scale.
The digital scale did not match the reference weights.  So I used the triple beam scale.
Despite the fact that the digital scale was not accurate, the owner’s son continued to use it.
According to this article, optical readings are going to be the most accurate.  I cannot imagine how to use it in woodworking, however:
https://www.mdpi.com/1424-8220/24/6/1755
I will have to re-read this a few times if I am to have any hope of understanding what he is saying.
2.1. Optical Methods
The optical scheme is mainly divided into interference methods and non-interference methods. The angle is measured through the interference phenomenon caused by displacement or orientation changes in interference methods. The measurement accuracy is high, but the measurement range is generally small because the cross-sectional area in the angular direction of the measurement beam is small. Non-interference methods are based on the changes in the energy distribution of the light beam caused by orientation changes. The measurement accuracy depends on the resolution and stability of the detector. Therefore, the accuracy is generally lower but the measurement range is larger. Both solutions have their advantages and disadvantages depending on the application field.
RS Pro has one available for about £150. I have never used the brand myself, so I can't vouch for it. However a friend of mine works at an after school machinist's training center for people who want to change career and thought they were OK as a brand. Not in the same league as Mitotuyo (which would indeed be in the range you mentioned), but quite usable.
Here's a good video on the Origins of Precision:=o4jLz7blkHRP-Whn&t=80
It's short, and if you're into history, kind of fun.
In 1834 the Imperial standards were destroyed, and the procedure for recreating them turned out to be flawed, but they found a copy and made that the standard, which survived until 1964!
The progression of Gauge Blocks, from costing more than engineers made in a year to now being available for under $100, NIST-chained, and accurate to a few millionths of an inch.
BTW, some of the Meter Standards (6:30 in the video) that France developed are still around and publicly accessible, so if you wanted to check your meter stick.... And, it's too bad they weren't successful with angles - instead of a right angle being 90º, it would have been 100º.
I found the data sheet for it here.
Its accurate to +/-5 minutes (1/12º). Here's an example of how to read it:
I think for ⅓ the price and the ease of a full digital read-out, something like the Wixey at 1/10º accuracy is preferable, but still not accurate enough for everything a woodworker might want to do.
RMW
I don't often but an example is setting an angle gauge to 43 degrees, 30+1+2+10.
RMW
bobtskutter said:
How do people set their saws to cut these super accurate angles?
I am currently making a stand with compound angles.  For this I need tenths of a degree.  Getting reasonable results from a Klein Digital Angle Gauge on the table saw blade, and a Jessem mitre gauge.
Bob
