Hey [member=1674]Peter Halle[/member] I just finished removing the turret and there was no debris under it. So I cleaned everything and relubed with some high pressure vacuum grease and the issue persists. The middle detent is off by about 1/2 of a position. [sad]
Which brings up an earlier issue, recently while milling some HVAC vents from Jatoba, the router plunged too deep on 2 occasions and I managed to put two 5/16" diameter router bit divots into an outdoor teak table. very [mad]
At the time, I blamed it on the router bit loosening up, but now I realize it was most likely that when I used the middle position and plunged, there is so little contact, that the turret simply turned slightly and allowed the router bit to plunge too far... [crying]...into the table.
Oh well, just another project to add to the list...
