OF 1010 REQ-F
TDJMB
Some oddities found in the Systainer.  There's a grease spot in the cup where the vertical rods would sit.  I hope it's just from the rods being lubricated and then grease going where it will.  I also found a screw (about 20mm)  and a small spring - no idea where they go.  And there seems to be an extra collet nut and lock for the trammel unit.
Edit: just watched a video - didn't realize there's a 1/4" and 8 mm collet and the screw is one of the screws that goes under the guide stop - I just need to find the little nut for it.
I ordered mine 2 weeks ago from Beaver Industrial, they had to hold off until the 25th, and then it arrived the 29th.  Hope you get yours soon.
