I've read numerous threads about people wanting to mount the 1010 in a table so thought I'd chirp in with what I did. Basically it's mounted the same way Festool does it in their own NAINA solution. I bought a Woodpecker ally router plate drilled to fit the PC 7518. It has four mounting hole which are spaced just a bit wider than the 1010 base sides. I removed the side foot and used a small kreg clamp ($5) over the bracket mount and a woodpecker aluminum track stop on the other side, though two kreg clamps will do as well. Lined up with a centering bit and clamped down.
with the base in place you can either use in the table or as a larger baseplate with a nice big straight edge.
http://img824.imageshack.us/f/plate1.jpg/
http://img28.imageshack.us/f/plate2s.jpg/
http://img153.imageshack.us/f/plate3p.jpg/
http://img710.imageshack.us/f/plate4.jpg/
it sits pretty solidly and still gives easy access to bit changing.
< Edited by Shane Holland to fix images links >
