Cheese said:I think this would be an appropriate query for Festool to answer. [smile]
They make the router...they make the router bushing...they certainly must have an answer, don't you think? [popcorn] [popcorn] [popcorn]
On a more serious note, I would contact Festool with this question and see what lame excuse they come up with today. If they were to actually answer you, that answer would indeed become a first as they've been asked this question hundreds of times and have never answered it even once. Instead they just continue to produce the 1400...continue to produce the problem and continue to never answer the question. They don't even bother to deflect the question...they just ignore it and act like you're the fool.
It's the reason you need a 1010, because the router bushing is adjustable like it should be.
15 years later, this simple fundamental issue still makes me more livid than the Kapex issue. Not so much because it exists and is real, but because Festool corporate still refuses to deal with and acknowledge the reality of this problem. At least with the Kapex, they released a new and improved version while never admitting responsibility. Admitting culpability is just not a German thing and they've honed that approach down to perfection...in their own eyes. The rest of the world knows the truth.
MikeGE said:I spent the past three days chasing ghosts with my Leigh D4R dovetail jig and the OF 1400. I bought the OF 1400 specifically for use on the Leigh jig after watching lots of videos with other happy owners using their OF 1400. After going through over a dozen test cuts trying to dial in the correct cutting depth for half-blind dovetails, I was not getting any closer to having a tight fit. I watched the Leigh troubleshooting video several times to make sure I was moving the router bit in the correct direction, nothing seemed to close the gaps.
This morning, I decided to reset everything to the recommended depth of cut and start over. That is when I noticed the entire guide bushing plate in the OF 1400 moves slightly side to side as I move the router between the fingers. Ugh...
I'll buy the plastic insert for the OF 1010 and try again when it arrives. I have a feeling the OF 1400 will be my first Festool machine that will gather dust.
ear3 said:[member=70363]MikeGE[/member]Leigh makes an aluminum one, which can be centered in the unit:
Cheese said:Edward, I think Mike's referring to the 469625 template guide adaptor. That's the one I use on my 1010 with a PC style bushing.
jeffinsgf said:Mike,
I have both the Festool and Leigh guide bushing adapters for the 1010. The Leigh is vastly superior, simply froim the fact it is metal rather than plastic. It is Leigh's part #704R and I center it with the Festool centering mandrel 492187.
I have been trying for over a year to get Woodpeckers to make something like the 704R for the 1400. One of the engineers and I even made a very successful prototype. But, it's hard to get anyone here excited about a replacement part to fix another company's shortcomings.
