peterfisp said:
OK, sending if off was the plan anyway. However, I still think that there is one specific problem with it. And it would just be useful to know in advance what that problem is.
thanks, guys, for responding.
The problem with your router can only be determined
by inspecting the tool itself.
I could repair your router if I had it in my hand, but not over the internet. Unless you go to someone with the technical know-how to do this, you're not getting any answers.
If you are comfortable opening power tools yourself and be confident you get everything back in the right order and do this safely, we could give you pointers for troubleshooting.
There are a number of things that could be the cause of your problem, from easy and cheap to difficult and expensive:
- worn brushes
- broken cord or Plug-It connector
- faulty On-Off switch
- faulty electronics module
- burned armature.
If I have to repair a power tool, I take these steps:
- open it, and clean everything I see.
- check the items mentioned above, generally in that order to see if they work or not, by using replacements or bypassing them. You can take each part out and apply mains power directly to the brushes to see if the motor works as it should.
Determining if the brushes are worn is the easiest. If that happens your tool simply stops and does not turn on again. Visually inspecting the brushes will show you an exposed spring inside the brushes. Replacing them is cheap and easy.
All other cases where the tools powers up intermittently, has speed fluctuations or weird noises can have a variety of causes and to find that you have to inspect each part individually and use a process of elimination.
