WoodWorkingEric
- Sep 8, 2012
Hello,
First post from a long time lurker. I'm working with my 1010 router trying to make a few bookshelves, and my LR32 setup is lining up great, but all my 5mm shelf pin holes are oversized.
I compared the router bit hole with a 5mm drilled hole, and the CXS drilled hole is nice and the pin stays in well. I put the router bit in the CXS and also drilled a hole, and that worked out great.
BUT, all my routed holes are "sloppy". A bit of experimentation shows if I tighten the plunge on the router, and plunger really slow, the hole is better, but still not as "tight" as the CXS.
Any thoughts on what I'm doing wrong would be greatly appreciated. To put things in perspective, I'm a fairly beginner wood worker.
-Eric
-Eric
