joiner1970
- Jun 13, 2007
I've got a 35mm cutter I use with my of 1010 router to cut hinge holes for concealed hinges. I'm about to change the old doors on a kitchen and thought I would make a jig to use with a 40mm copy ring (guide bush). That's the maximum size the of 1010 will take, but the internal size is only 37mm so only 1mm clearance all round. Has anyone used a 35mm cutter with the 40mm copy ring and was it ok ??
