OF1400 cutting capacity?
ForumMFG
Hello all.
I have a question regarding the OF1400 cutting capacity.  Today I was routing 3" x 3" hard maple.  I was using a edge trimming bit w/ bearing at the top.  It has a 1" cutting Dia. with 1 1/2" cutting length.  When I was doing my routing, all of a sudden the router tripped the breaker and split the wood about a 1/4" deep x 7" long x 1 1/2" wide.  Is this bit I'm using to large for the OF1400.  Is this a task for the 2200?
FYI, I was taking a 1/2" x  1 1/2" material off by 20" long each routing.
-Dave
If I am reading you right the bit depth was 1.5" and .5" in width I would say that that is way too much material to remove especially in maple.  I would not try this and I am quite cavalier about bit depths .  I would suggest using the depth turret and taking multiple passes.  I once tried to joint a piece of maple on my router table before I got a jointer and that was something like a 32nd" by about 1.75" and it totally frayed the wood and shot it across the shop.  Maple is a very hard wood and small increments at a time are important even if it takes longer.
JJ
The Bit was 1" dia. x 1 1/2" long and I was taking a 1/2" x 1 1/2" material off at a time.
I couldn't use the turret for the type of bit I was using and application.  It was a pattern bit so it had a bering at the top.  It was the only bit I had that I could use for the job.
I agree with JJ, that's too much material to remove in one pass. I'd try something like that in two or three passes depending on how hard the wood is.
Wow, that is a big bit and an equally big bite. If you must remove 1/2" material due to the size of your template, then I suggest taking nibbling cuts to trim this down in stages. It is a slower process, but is necessary for doing what you are describing.
I don't specifically cover this procedure word-for-word in the manual, but the underlying concepts are presented in both the OF1400 manual (page 14) and OF2200 manual (page 17), where I discuss taking a nibble of a cut using a pivoting motion to control the router position. These two manuals are available at http://www.waterfront-woods.com/festool/ or from the Festool USA website.
It is clear that the amount being cut was way too much in almost any wood other than balsa  :) and it is a complement to the power of the OF1400 that it could do this at all. Another point is that unless the shank was 1/2" there would be a good chance of breaking the bit itself and even 1/2" shank bits can self-destruct if pushed too hard.
Rick's manuals are really good, give excelent advice and tips. I am waiting for the MFK 700 to be released (any time soon Rick?) as I am sure there will be things I haven't found out yet in it.
