OF1400 Leveling Outrigger
Monju123
I have recently purchased both an OF1400 and the guide stop to use the guide rails. Apparently, a "leveling outrigger" is used to keep the router from tilting on the rails. Should this come with the router or the guide stop, because I got it in neither?
Mine came with the Guide Stop.  I double checked in the catalogue and it confirms that the hight adjust gizmo should come with the Guide Stop.
I ordered one, but found it was included also. Now I have two.
nickao
  Speaking of the leveling outrigger- I still havn't gotten around to making a leveling sub-base.  I was using the outrigger the other day and I have started having a problem with it not holding tight enough.  I tighten it as much as possible but it has started to slip when I plunge. I am thinking a lock washer of some type might do the trick until I get the base made. Up till now it has been working fine.
It was almost 5 minutes before I had an answer to my question! Movin slow today,eh?
Really, thanks for the replies.
