Taylorkitchens
- May 23, 2013
Hey guys, I'm new to the forum as I have just bought my first festool 'tool' being the of2200 router as I do a lot of kitchen fitting it seemed the best router. I have come across and issue with it and wanted to pick someone's brain about it.
I have had it 2 days, used it for the first time today off a Honda 5.5hp 2.7 kva generator, I also had a hilti vc20 vacuum running of that very same generator. While cutting my first masons mitre with both router and extractor running of the generator at the same time it's bog very slightly but work perfectly well at high speed. But when I got the my second joint, female and male cut and one bolt recess left to do then 2 joints router, it started to make a were'ing sound almost like when a generator starts to run out of petrol on the last bolt recess hole. It had got that far fine.
So I rung the guys where I bought it from and they said they'll send it back as I know the service is second to none when it comes to festool so I tried it off a transformer plugged to Mains fine, so i tried it on the generator this evening and when set to speed 6 it seemed to work fine again, but if I were to adjust that speed dial to 5 down to 1 it would make that were'ing sound and seem powerless.
What I can't work out is why it didn't do it from the word go?!
