OFK500 Advice
VW mick
Hi guys
Just about pushed the button today (neelemans fault) but just wanted to know about the cutter situation ..can it not be changed ?
The OFK500 doesn't use 'normal' router bits, only special ones, but there are a few available. There's the flush trimming bit, chamfer bit (45 degree), and then radius bits from 2mm up to 6mm in 1mm increments.
Think I will still go for it .dont think I'd want it for anything other than that anyway
Anyone know the cutter part nos
VW MICK said:
Hi guys
The cutters are only produced by Festool.
They don't come cheap at around €76-89 incl. VAT.
Of course they can be changed because there are around 9 models.
There is a screw in the center of the hollow axis which disconnects the router bits.
Man, you missed the 30 and 60 degree chamfers AGAIN!  [poke]
After you'd edited your original post I linked to above too...  [wink]
[attachimg=2]
[attachimg=3]
Yeah. I thought they existed, but wasn't at all sure & couldn't be arsed looking it up..  [unsure] My bad.
Thanks guys ..good advice
Think it comes with one cutter .So I will order one each of the others .Because if I don't get them with it I probably won't .Then it will be less usefull
Also it will be my first 240v festool
