thudchkr
- Dec 13, 2007
Good day to all.
We, me and the wife, are being forced from our home of the last 34 years so the city can improve their flood protection. They are, at least, giving us a “fair” amount for our place. I had a decent shop setup there other than not Having enough room.
Finding a new place with either a shop, or enough room to build, has been a trying experience. We finally found a place and will close on it today. The new residence has plenty of room in the house for the two of us as well as the following options for my new shop.
There is a 28’ x 28’ double car garage attached to the house. It is insulated and has an adequately sized gas heater that should be able to keep it comfortable, even during the winter, (negative 30s or colder). We want to be able to use this for our vehicles, needless to say, but it can/could be used in the meantime.
There is a 50’ x 28’ pole barn on the property as well. It has two sets of large sliding doors as well as a personnel door. Probably 14’ to the bottom of the trusses. No insulation here, and it has only the original dirt floor. There is no electrical to the building, other than an extension cord that was fed through a PVC pipe from the garage. There is a bit of two level storage at the back that could use some reinforcing to make it viable for my use.
We are considering building a new structure as well. Current zoning would allow me to construct up to an 800 sq ft “shop” in addition to the existing pole barn. I would most likely incorporate radiant floor heating in such a building as well as sufficient windows to allow natural lighting.
Part of our “buyout” provides that up to $25K is available to re-establish my business at the new residence. This can only be used on existing facilities, and not for use on new construction.
As such, this is the current thought on how to go forward.
Pour a concrete floor in the pole barn, run electrical to it, and install a large enough service to suit any shop needs. Probably means a 200A panel, as 3-phase is not available here. My improvements here should be able to reimbursed as part of my business relocation. Depending on funds availability, may also spray foam the inside of the walls/ceiling to facilitate heating in the the future. The pole barn would be used for storage of wood and other items, and I would position some of the larger machines out there such as the table saw, jointer/planer, and shaper. Some type of dust collection would be installed, (I’m bringing a 2hp Oneida cyclone from the old shop), and this area would be used for shaping and milling operations. It would, however, also be used for storage of a small Kubota tractor with associated implements and whatever else may need to come in out of the elements.
Build a “new” 32’ x 25’ shop as well. This would house the hand tools, the Festools and Mafells, and some power tools such as my two wood lathes and bandsaw. My Roubo workbench, along with the stable of MFTs would live here as well. Some form of dust collection would be in order, but would probably not need the capabilities of that used in the milling area. This area would be well insulated with in-floor heat planned, but I am still in the air on what, if any any A/C.
The existing garage will be used until the new areas are established. The power available there is lacking, but not totally non-existent. It should be able to tide me over.
If you’re still with me after all this, I’d appreciate any comments, suggestions, and/or improvements.
Thanks in advance.
Thanks in advance.
