I’ve sprayed thousands of gallons and have trained many to spray Kem Aqua and Kem Aqua Plus through an HVLP. I own a Fuji Q4 and a Q5 and 5 Fuji guns, all with PPS systems. Never had a finish issue. Then again, I’ve only been spraying finishes for 56+ years, no telling what tomorrow will bring.
To this day the Fuji’s still get used, mostly for field work where I’m spraying touching up finishes that have been sprayed through a Graco FF 395 AAA PC or a Graco Merkur 15:1 air driven AAA. There is no difference in the dried films. The reason I’ve moved away form the Fuji’s in the shop is speed. The AAA’s are that much faster when applying a finish than the HVLP’s, even with a pressure pot connected to the HVLP gun. In a week we’ll apply 100 gallons or more of primer, finish or a combination of the two.
About 2 years ago I moved from KA+ to SW Hydro Plus. KA+ is an acrylic, HP is a urethane that can be treated with a hardener.
About 7 months ago I hired a young lady who had never held a spray gun in her life. Now her finishes are flawless, she can rebuild any one of the guns, be it HVLP or AAA. She has seen me rebuild a AAA pump but has not had to rebuild one here self—-yet.
The little bubbles are called micro foaming, they’re caused by improper air introduction. Get the air right and they’ll go away. On a HVLP gun, this may mean mixing air caps to the needle and nozzle combination. On a AAA, there air regulators and pinch valves to control air introduction.
BM owns Cabinet Coat, closest BM product to KA+.
If you can get KA+ use it, DO NOT in any way mix KA+ and KA. DO NOT apply one over the other.
Use SW Gen II primer.
Make sure you prep properly, this is where most of the magic that gives you a great finish occurs.
Learn to use the Ford 4 cup that came with the Fuji.
What gun did you get with the Fuji?
